Author
Comment
nomogm
Registered User
(3/3/03 10:29 am)
Where to drill hole in firewall - for Mind Freedom
Mind Freedom,
I got your private email. You are welcome to email me at any time, but the message said I could not respond because you have private messaging turned off.
Look up under the dash to the left of the brake pedal on the firewall. You see a perforated area on the foam padding. You can easily remove that section of the padding. That is where the clutch would be if you had one. If you have a manual, then you can find another location.
By measuring carefully I determined that if I drill a hole in that area, from the inside, I would hit nothing on the other side of the firewall. I am sure there are other good locations too. It's tight in there so maybe you would prefer to drill from the engine side, or tey one of those rubber
grommets that are higher up.
I drilled a small hole, then used a larger bit to get the size I needed. I got some rubber
grommets at the autoparts and made my hole as big as the grommet needed to fit snug into the hole, using the
grommet that best fit my wire. I fed the power cable through and worked the
grommet into the hole carefully using a very small screwdriver.
You just have to be certain that when you drill a hole you do not hit the power brake booster or anything else. You can do things like measure
horizontally from the steering column or whatever. Remember to measure twice and cut once. Just check and double check and be sure you have it in a good spot, then drill it.
Actually since I am not that good at these things I like to measure three times and cut twice.
If you really have trouble getting a rubber grommet in there I suppose you could wrap the section of wire that goes through the hole in some electrical tape and apply some silicone adhesive to fill the gap and keep the wire from rubbing.
I am sure you know this, but be absolutely certain to install your fuse very close to the battery. Don't allow any possibility that the wire could short out. If nothing else the wire can short in a front end collision. I mounted my fuse on top of the air box. I drilled two holes and use screws along with double sided tape. If I did it again I'd find a way to locate the fuse right on the battery, next to the positive terminal.
My wiring kit came with a 60 amp fuse. But a web site said that gauge of wire for that length should be fused at 50 amps maximum so I changed it to a 30 amp if I remember
correctly. My amplifier has a 30 amp fuse and draws up to 27 amps.
It was my impression that the amp should be grounded as close to the amp as possible. I located the amp under the seat and used the seat bolt for the ground. |
Mind Freedom
Registered User
(3/3/03 12:24 pm)
Re: Where to drill hole in firewall - for Mind Freedom
Well thank you very much for that information. But i already found another hole. i used the hole inside the glove box to run the wires. but thank you any way because i may decide to change it. well off to the
Santa fe to change my grounding points |
nytopskier
Registered User
(3/4/03 12:13 am)
hey, randy here, nytopskier 3-3-03.... i also am having problems getting through the fire wall. where is that hole you were
talking about in the glove box
randy |
Mind Freedom
Registered User
(3/4/03 3:48 pm)
This is what you have to do.
1. Remove glove box.
(4 or six screws)
2.Open hood and remove one screw from the weather stripping on the left (or right side of vehicle) and pop out all the plastic clips.
3. lift up the weather stripping and look into it with a flash light.
do you see that filter type thing like you do on the other side of the glove box. well next step then
4. tape the power wire to a straight coat hanger and give the coat hanger about 3 inches before you tape the wire to it.
( like this <------------=================
coat hanger I I Wire and Coat Hanger
Then fish it threw at the top of the filter looking thing. Either have one person on the other side ready to grad it when it comes out or push it threw and go around and grab it your self.
5. then just run all the wires how ever you want.
This is where it comes threw on the outside.
this is where it comes threw on the inside behind the glove box.
Hope I Helped |
nomogm
Registered User
(3/4/03 3:54 pm)
Mind Freedom,
Alright! You actually figured it out without having to drill a hole. Congratulations! |
nytopskier
Registered User
(3/4/03 6:59 pm) |
thanks, ill try that tonight. |
Mind Freedom
Registered User
(3/5/03 8:15 am)
Hey Nomogm where do you live. I am definitely down for drinking some beers, but hey how about instead of drinking them on your front yard lets park the Santy up in the drive way and drink them in there so we can listen to that awesome system
I got in there ahahahah ill talk to you guys later I have to get back to work now |
nytopskier
Registered User
(3/5/03 7:08 pm)
Fire Wall head ache and a 1/2
listen, i tried the method behind the glove box, I'm no professional installer but that was a pain in the neck. Meantime i did not run the wires that way because of some chimney looking thing in my way, and also I cracked the plastic
windshield lower piece. chipped not cracked... I hope Hyundai will replace it. I think it cracked from the cold. But now
I'm back to square 1. I need to get thought the fire wall and I know there is a magic
hole some where, i just have to find it. I think if is jack the front right of the car, take off the wheel, then the plastic wheel well area I will have full access. But I had a
Nissan 240 and the hole in the fire wall was boom bam right there smack in full sight, a 2 yr old could do the wire job. I'm tired of making this into such a project, buy some lights, hook em up..... 2 weeks later
I'm still looking at the fire wall night after night staring and studying for that magic hole. |
retired in bama
Registered User
(3/5/03 9:15 pm)
Re: Fire Wall head ache and a 1/2
Randy,
There are several posts in here about where to drill through the firewall. Several have gone through about where a clutch pedal would be; if you pull back the carpet in that area there is supposed to be some sort or rectangular or oval cut-out where the under padding comes loose. You need to measure a zillion times and ONLY DRILL ONCE. Look at it from inside the vehicle, from under the hood etc and measure almost exactly where you want to drill. Watch out for the brake booster which can be in the way if you are not careful. I have not drilled in the firewall but several members have in the area I just described. Go for it!!!
Did you try removing the large rubber grommet on the driver's side of the firewall (engine side)?? I posted a pic of that somewhere. See if you can run a coat hanger or heavy gauge copper wire through there and see if you can get it to come out inside and under the dash...if so, you can tape your wires to that and pull them through to the engine compartment. |
nytopskier
Registered User
(3/5/03 11:24 pm) |
fire wall
i know, i know, about that grommet but it leads to nowhere. I will not drill and take the chance of messing up my baby. bad enough
I'm willing to follow wiring direction and chance myself but drilling no.... There is a magic hole and I will find it. |
Mind Freedom
Registered User
(3/6/03 8:34 am)
Re: fire wall
dude your not gonna find a hole. actually you probably will. if you look under the dash there is a
grommet down there that does lead into the wheel well. and it can be run threw there but it takes about 3 hours of work to get it threw there and a nice car jack. also you will have to take off the plastic shielding in the wheel
well to find the other side of the hole. but i am telling you just go threw the glove box. hey if you live in the
Philadelphia area ill stop by and do it for you. |
twospirits
Moderator Posts: 1867
(3/6/03 12:29 pm)
ezSupporter |
Re: fire wall
To All:
I resized the pic, even though the proper thing to do is to resize it in any pic program and then upload the smaller pic for viewing. If you click on the pics they will open up in a new window in their original size. |
nytopskier
Registered User
(3/7/03 11:51 pm) |
fire wall
oh my god guys, please don't disrespect me or loose confidence in my Santy love but i paid a pro to wire up my light who by the way DRILLED
though the fire wall. They look great and at least i know there wired up right. |
twospirits
Moderator
(3/8/03 1:16 am)
ezSupporter |
Re: fire wall
How much did you pay and where, maybe I'll take my Santy in to hook up my side steps and spoiler. |
onigoroshi
Registered User
(3/8/03 1:20 am) |
Re: fire wall
randy, you lost my respect.... just kidding! glad you got it done finally! |
nytopskier
Registered User
(3/8/03 7:26 pm)
(3/8/03 7:26 pm)
install
i went to EZ riders 225 Hempstead turnpike, Hempstead ny
nytopskier
Registered User
(3/8/03 7:26 pm)
install
west hempstead, sorry
twospirits
Moderator
(3/8/03 7:45 pm)
install
Thanks for the info Randy, Not that far away.
Edited by:
twospirits
at: 6/14/05 2:25 pm
nytopskier
Registered User
(3/8/03 7:26 pm)
queens
hey queens,
gather your friends, lets go for a drive
Randy
twospirits
Moderator
(10/26/05 8:45 pm)
install
Added more pics of the firewall area, provided by fellow moderator Metal
Messiah.
Pic of the inside cabin, where the clutch would be. This is where Metal drilled
through.
The hole from the other side (in the engine bay area)
Another view from the engine bay area.
TS out
